Введение
This guide will show how to remove, disassemble, and replace the chainrings from the crank arm on a Giant Talon 29er bicycle. The chainrings should be replaced when the chain starts to skip teeth while riding.
Выберете то, что вам нужно
Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
Unroute the chain from the chainrings.
Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
Rotate the largest chainring 45 degrees in either direction.
Remove the crank arm from the chainrings.
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
Еще один человек закончил это руководство.
