Введение
This guide will help you replace the hard drive in a gigabyte laptop if the main hard drive has failed or you are looking to upgrade it. If you have your original install disk, or a disk imaging software, you can use this to place windows back on the new hard drive. If not, you will need to purchase a new copy of windows to place on the replaced hard drive.
Выберете то, что вам нужно
Locate the small plastic back plate.
Remove the small 4.0mm screw holding the small plastic back plate in place.
Disconnect the small red and black cord connecting motherboard to the case using a small flathead screwdriver.
Remove the removable drive bay or CD drive, whichever one is currently present in the laptop.
Remove the 8 longer 7.0mm screws from the top and bottom of the laptop.
Remove the 6 shorter 5.0mm screws from the middle of the laptop.
Beginning from the hole created by removing the drive bay in step 6 and moving in a counterclockwise direction, begin separating the base by gently prying between the seam separating the base from the mother board, using either your fingernail or a small flathead tool.
Carefully place base plate aside, ensuring not to disconnect the wire which runs from the motherboard to the baseplate.
Disconnect the battery from the motherboard by gently prying the plastic connector apart
Remove the SATA connector by gently prying the far right, and then the far left of the connector until it slides out of the hard drive.
Remove the hard drive from the laptop by picking it up.
Un-screw the metal holder by removing two more screws, one on either side of the hard drive.
If replacing with an identical hard drive, repeat all the steps backwards and if necessary, reinstall windows.
If replacing the hard drive with a solid state drive, there may be a small gap between the metal holder and the top of the SSD, but this is normal.
6 участников успешно повторили данное руководство.
