GoPro Hero 3+ Silver Edition Motherboard Replacement
Выберете то, что вам нужно
  1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 2, изображение 1 из 1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero 3+ Silver Edition Motherboard Replacement, Front Panel: шаг 3, изображение 1 из 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 4, изображение 1 из 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: шаг 5, изображение 1 из 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: шаг 5, изображение 2 из 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: шаг 5, изображение 3 из 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    Is this the power cable?
    David - Ответить
  6. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 6, изображение 1 из 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 6, изображение 2 из 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 7, изображение 1 из 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 8, изображение 1 из 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 8, изображение 2 из 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero 3+ Silver Edition Motherboard Replacement, Motherboard: шаг 9, изображение 1 из 1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  10. GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 10, изображение 1 из 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 10, изображение 2 из 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: шаг 10, изображение 3 из 3
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
Заключение
3 участников успешно повторили данное руководство.
Blake Ehlers
Участник с: 10/01/15
668 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-8, Maness Fall 2015 Участник Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 членов
Автор 12 руководств
2 Комментариев
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 3,436
