Выберете то, что вам нужно
Gently pry the back open by inserting a metal spudger between the case and back panel.
Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
Remove the two screws located on each side of the board with a Phillips screwdriver.
5 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
