GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
Выберете то, что вам нужно
  1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: шаг 1, изображение 1 из 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 2, изображение 1 из 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 3, изображение 1 из 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 4, изображение 1 из 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 5, изображение 1 из 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 6, изображение 1 из 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: шаг 7, изображение 1 из 2 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: шаг 7, изображение 2 из 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 8, изображение 1 из 1
    • Remove the two screws located on each side of the board with a Phillips screwdriver.
    • The screws go through an L metal bracket that will come off with the screws.
  9. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: шаг 9, изображение 1 из 1
    • Separate the daughter board from the white plastic piece.
Заключение
5 участников успешно повторили данное руководство.
River Drake
Участник с: 04/02/15
1 023 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-2, Lancaster Spring 2015 Участник Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 членов
Автор 18 руководств
4 Комментариев
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - Ответить
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - Ответить
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - Ответить
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 4,762
