Введение
Oops! You scratched the front of your GoPro and you don't want others to question if you take care of your camera. Let's replace that face plate and make it look good as new!
Insert a plastic opening tool in between the front face plate and the black housing.
  • Insert a plastic opening tool in between the front face plate and the black housing.
  • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
Добавить комментарий
Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
  • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
  • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Заключение
3 участников успешно повторили данное руководство.
Patrick Cook
Участник с: 01.10.2015
628 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-8, Maness Fall 2015 Member of Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 5
За всё время: 336
