Введение
Are you having trouble saving all of the cool videos and photos you record? You've tried everything and nothing will work? It may be time to get a new microSD and accessory board so you can enjoy the adventures for years to come!
Выберете то, что вам нужно
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
Removing this and attempting to reconnect the connector ribbon will be really difficult when re-assembling. If you are simply replacing the LCD screen I recommend skipping to Step 13.
Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
Remove the image sensor from the motherboard assembly.
Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
The threads on the top left screw are different so be sure to take note of which screw is which (although maybe it doesn’t matter that much).
Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
The microSD/accessory board is ready to come off.
6 участников успешно повторили данное руководство.
Один комментарий
I bought a replacement from iFixit. I follow the guide, but it still shows same error “No SD”. Any advice?
