Введение
You've had a terrible accident and realized that your GoPro has a crack right through the center of the lens! Use our guide to resurrect you GoPro back to life!
Запчасти
Push the tab on the back of the device left to remove the plate covering the battery.
Insert a plastic opening tool in between the front face plate and the black housing.
Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
Pry off the last ribbon cable with a plastic opening tool.
Remove the image sensor from the motherboard.
Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
The microSD and Accessory Board is now ready for removal.
Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
Gently remove the motherboard from the midframe using tweezers.
Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
8 участников успешно повторили данное руководство.
