Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a #00 Phillips head screwdriver, remove the following screws:
One 4.6 mm screw
Three 8.2 mm screws
Two 6.1 mm screws
Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
Using #00 phillips head screwdriver, remove the 3.0mm screw.
Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
Using tweezers, lift the motherboard from the midframe housing
Using #00 phillips head screwdriver, remove the three 4.0mm screws.
Using plastic opening tool, unclip Expansion Port chip from motherboard
Lift the expansion port chip from the motherboard.
It is now possible to replace the expansion port and/or motherboard.
9 участников успешно повторили данное руководство.
Один комментарий
step 2 is wrong, short screw belongs on the battery door edge... destroyed my new housing... :(
