Выберете то, что вам нужно
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a #00 Phillips head screwdriver, remove the following screws:
One 4.6 mm screw
Three 8.2 mm screws
Two 6.1 mm screws
Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
Open the clip that is located on the motherboard
Use a pair of tweezers to pull the ribbon from the clip
Place the iOpener on the LCD screen cover to release the glue
Lift the covering of the LCD screen cover off with a pair of tweezers
Use a pair of tweezers to lift the ribbon through the opening and lift all the way up to the LCD screen
Place the iOpener on the LCD screen to remove the glue
Use a pair of tweezers to left the LCD screen off the device
5 участников успешно повторили данное руководство.
2 Комментариев
You got the screw locations on the front wrong. Bottom left is the shortest screw, where the battery compartment is. If you try putting one of the longer screws through their it'll bust into the battery compartment. Ask me how I know. And that's the one reason why I came to this, the one thing I couldn't remember.
