GoPro Hero4 Silver Hero Port Assembly Replacement
Выберете то, что вам нужно
  1. GoPro Hero4 Silver Hero Port Assembly Replacement, Front Panel: шаг 1, изображение 1 из 3 GoPro Hero4 Silver Hero Port Assembly Replacement, Front Panel: шаг 1, изображение 2 из 3 GoPro Hero4 Silver Hero Port Assembly Replacement, Front Panel: шаг 1, изображение 3 из 3
    • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
    • The seven plastic tab locations are marked in red.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
    • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
  2. GoPro Hero4 Silver Hero Port Assembly Replacement, Image Sensor: шаг 2, изображение 1 из 1
    • Remove the three 8 mm Phillips #000 screws on each corner of the camera.
    • Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
  3. GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 3, изображение 1 из 2 GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 3, изображение 2 из 2
    • To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing.
    • To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the motherboard assembly open, but found that it did not give us enough leverage.
    • Do not try to pry near the power button side of the camera. This will break important cables inside.
  4. GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 4, изображение 1 из 2 GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 4, изображение 2 из 2
    • Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
  5. GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 5, изображение 1 из 3 GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 5, изображение 2 из 3 GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 5, изображение 3 из 3
    • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
    • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
    • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
    • With the old camera sensor assembly removed, you can now replace it with a new sensor.
  6. GoPro Hero4 Silver Hero Port Assembly Replacement, Hero Port Assembly: шаг 6, изображение 1 из 1
    • Remove the three 8 mm Phillips #000 screws securing the Hero port to the motherboard.
  7. GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 7, изображение 1 из 1
    • Locate the copper-colored ribbon cables connecting the Hero Port to the motherboard.
    • To remove the connector, use tweezers or a spudger, pry up each side of the connector. Then, lift the connector straight up from it's socket.
    • When reassembling this piece, do not use too much force to put the black rectangular pins back onto the motherboard. When done right, there will be a 'click'.
  8. GoPro Hero4 Silver Hero Port Assembly Replacement: шаг 8, изображение 1 из 1
    • To remove the free port, simply slide it out from the left side of the camera. It should come out with slight coercion.
    • This piece can be replaced, fixed, or set aside for further tear-down of the GoPro.
    • Pictured left is the port when separated from the motherboard.
Заключение
3 участников успешно повторили данное руководство.
Bradley Welsh
Участник с: 08/26/15
755 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-1, Blackwell Fall 2015 Участник USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 78
За всё время: 8,265
