Введение
Replacing an arm on the Karma can be done in less than 20 minutes. There are four main steps: removing the landing gear, removing the old arm, installing the new arm, reattaching the landing gear. This video will walk you through each step.
Выберете то, что вам нужно
Видеоинструкции
3 участников успешно повторили данное руководство.
3 Комментариев
Juste merci !
cedricgaeta - Ответить
Can someone tell me what tools are needed? I’m looking first to see if I can repait a slightly cracked arm before needing to replace?
lenodski - Ответить
The only tool needed is a 2.5mm hex key.
Blake Klein -
