Введение
Replacing the landing gear in your Karma is a relatively easy task, but requires caution because of small screws. There is a specific tool to help remove the clips connecting the arms but it is not necessary at all. Removing the clips without that tool can be tedious and requires a soft touch so be sure to go slow.
Выберете то, что вам нужно
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
Flip over the landing gear and locate the cable connector.
Use your thumbnail to disconnect the cable and free the landing gear.
Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
Remove the cover plate by pulling up on the side.
Feed each connector through the hole and set aside the cover plate.
Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
Pull up and off the broken arm.
Еще один человек закончил это руководство.
