Введение
Replacing the harness for the GoPro camera is fairly easy. We will tell you how to remove the stabilizer which holds the harness, how to remove camera from the harness, and how to replace the harness itself.
Выберете то, что вам нужно
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
Еще один человек закончил это руководство.
