Введение
Use this guide to replace the speakers in the Google Chromebook Pixel 2.
Выберете то, что вам нужно
Remove the three red 4.5 mm Phillips #00 screws from the speaker on the right sight of the motherboard.
Using the plastic opening tool disconnect the speaker wires from the motherboard,
Using the plastic opening tool, pop out the connector that joins the headphone jack port on the left side to the motherboard.
Remove the red 4.5 mm Phillips #00 screw from the top of the headphone jack port.
