Введение
This guide will teach you how to take apart your Google Home to remove a broken or torn interconnect cable and replace it with a new one.
Выберете то, что вам нужно
Pull off the Google Home’s magnetically attached base and set it aside.
Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
After all four screws are out, pop the lid off the device to open the capsule.
Один комментарий
What cord can you replace with? There is an adaptor attached.
