Введение
A guide to disassemble Google Home Mini for further repairs.
Выберете то, что вам нужно
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Remove the lower half of the device.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
12 участников успешно повторили данное руководство.
2 Комментариев
How did you get the rubber base off of it?
There’s a little more explanation here
