Введение
A guide to change Google Home Mini USB power port.
Выберете то, что вам нужно
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
9 участников успешно повторили данное руководство.
8 Комментариев
Where I can buy micro USB PCB ?
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Has anyone had any luck buying a replacement part?
