Введение
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to apply replacement adhesive to your Pixel 2’s display.
Before you begin, you should already have removed the Pixel 2’s display. Detailed instructions for removing the display can be found here.
Выберете то, что вам нужно
Remove any trace of the old adhesive from the Pixel 2's case.
If you're reinstalling your existing display, be sure to remove any remaining adhesive from the back of your display as well.
After removing all traces of glue and glass, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%). This will ensure a better seal for the display.
Carefully tear along the perforations to separate the outer portion of the adhesive backing from the adhesive strip.
Peel away the white backing, exposing one side of the adhesive strip.
Carefully place the adhesive strip on the phone case, with the exposed side down, and the blue backing up.
Start at the bottom of the case, lining up the contours along the bottom edge of the adhesive with those of the case. Then lay down the rest of the adhesive.
With the adhesive lined up with the edges of the case, use your finger or a spudger to press the adhesive strip down against the case.
Use a pair of tweezers to remove the inner portion of the blue backing. It may be necessary to hold the adhesive down with a spudger to avoid pulling up the adhesive strip.
Use tweezers to peel away the blue backing over top of the adhesive without peeling the adhesive off of the case.
Getting this in place was really a pain. In a few places, it flipped 180deg on my but I don’t think it matters since the screen will compress the adhesive strip when you finally press it back.
17 участников успешно повторили данное руководство.
Один комментарий
Adhesive tend to stick inside the bag, use extra caution to remove sheet from the package.
Do not touch adhesive at any point, you might mess up the forming of the adhesive.
The grey liner on the inside of the case is dissolved by rubbing alcohol. Don't get any on it.
user39581 - Ответить
