Введение
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
In this guide, we are going to replace a Google Pixel 2 rear camera lens glass. Note that this is a glass replacement, not a lens replacement.
Take caution not to scratch the lens when removing the glass in Steps 2 and 3.
Выберете то, что вам нужно
Blow dry the broken or scratched rear lens glass until it is a little bit too hot to touch.
Remove the broken/scratched glass using a pair of tweezers.
Use a blow dryer to remove dust and tiny pieces of broken glass.
Apply the clear silicone waterproof sealant after the lens frame is neat and clean.
Use a wooden toothpick to gently apply the silicone sealant to the ledges of the inside shelf of the lens frame.
Remove excess silicone from the edges using alcohol wipes. Make sure the lens is leveled evenly and flat.
The Google Pixel 2 rear camera glass replacement is a difficult task to do and being extra careful is a must or lens can be damaged.
Еще один человек закончил это руководство.
