Введение
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
This guide will show you how to replace the headphone jack in a Google Pixel 3a XL.
The Pixel 3a XL’s display panel is fragile. If you plan to reuse your screen after this repair, be sure to pay special attention to the warnings in the opening procedure.
Выберете то, что вам нужно
For reference, the backside of the screen is shown in this step.
Note the narrow clearance between the edge of the screen and the OLED panel under the glass. If you plan to re-use your screen, be sure to follow the instructions below closely.
Also note the two different seams between the body of the phone and the screen:
The screen seam: where the screen meets the rest of the phone. This is where the screen will separate, and where you should pry.
The midframe seam: where the midframe meets the body of the phone. This part is held down by screws. Do not pry at this seam.
Place a suction cup on the right edge of the screen, just below the volume button.
If you aren't careful, the plastic opening tool can damage the fragile OLED display panel underneath the glass.
If you want to re-use your phone's screen, make sure you insert your pick at a downward angle, as shown in the second photo of this step.
This will ensure the opening pick slides under the OLED panel rather than between the glass and the panel, which will ruin the screen.
Pull up on the suction cup with a strong, steady force to create a gap between the screen and the phone.
Insert your opening pick into the gap.
Stop if you feel the tip of the pick hitting against something. The pick may be pressing against the edge of the OLED panel. Angle the pick downward and try again.
Once the pick is inserted, slide it up and down along the right edge of the phone to cut though the adhesive holding the screen in place.
If you plan to reuse your screen, heat up the top edge of the phone with an iOpener, a heat gun, or a hair dryer to loosen the adhesive there before you begin slicing.
Carefully slide your opening pick around the upper-right-hand corner of the screen.
If you plan to reuse your screen, take special care in this step to either keep your pick deep in the phone under the OLED display (as shown in this step's photos), or only insert it 5 mm into the device to avoid coming into contact with the display under the glass.
Slide your opening pick down the left side of the phone to separate the adhesive there.
If you plan to reuse your screen, heat up the bottom edge of the phone with an iOpener, a heat gun, or a hair dryer to loosen the adhesive there before you begin slicing.
Slide your opening pick along the bottom edge of the phone to separate the last of the adhesive holding the screen in place.
Don't try to remove the screen yet! It is still connected to the phone by a display cable.
Lift the screen by its top edge (where the front-facing camera is) and carefully flip it 180° so that the screen is resting face-down on the phone.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the two 4.3mm T3 screws holding the display cable bracket in place.
Remove the display cable bracket.
Pry up on the cable connector with the pointy end of a spudger to disconnect the screen from the phone.
Remove the screen from the phone.
Compare your new replacement part to the original part. You may need to transfer remaining components such as the speaker grille and the camera bracket to the new part.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Use tweezers or an opening tool to remove all traces of adhesive from the phone frame. You can use high concentration isopropyl alcohol to help with the cleaning.
If you plan to re-use the screen, be sure to remove all adhesive residue from the screen. Be careful with metal tools to avoid scratching the screen.
Apply pre-cut adhesive or double-sided tape (such as Tesa tape) to re-attach the screen to the frame.
Remove the following 4.3mm screws:
14 silver T3 Torx screws
2 black T3 Torx screws
Insert an opening pick into the seam along the bottom of the phone.
Slide the pick along the seam to release the clips holding the midframe to the rest of the phone.
Slide the opening pick along the left and right edges of the phone to release the midframe clips there.
Lift up the bottom edge of the midframe but don’t completely remove it yet. The midframe is still connected to the phone by a fragile cable.
Use a spudger to pry up and detach the proximity sensor cable from the motherboard.
This takes a bit of patience and finesse. Once you have the connector aligned, you can also use a finger to gently press the connector onto the socket.
Use a spudger to pry up and disconnect the battery connector.
Use the pointy end of a spudger to pry up and disconnect the headphone jack's motherboard connector.
Repair didn’t go as planned? Check out our Google Pixel 3a XL Answers community for troubleshooting help.
2 участников успешно повторили данное руководство.
