Введение
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the loudspeaker module on your Google Pixel 4 XL.
The loudspeaker is sealed against the frame with an adhesive gasket. If you remove the loudspeaker, the Pixel will no longer retain its water resistance.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
Выберете то, что вам нужно
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Insert a second opening pick underneath the back panel directly over the charge port.
Slide the opening pick to the bottom left corner of the phone.
Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
Stop when you reach the top left corner, near the camera, and leave the pick inserted.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
Stop when you reach the top right corner, and leave the pick inserted.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the four T3 Torx screws securing the battery connector shield:
One 1.8 mm screw
One 4.1 mm screw
One 4.4 mm shouldered screw
One 4.0 mm shouldered screw
Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
Using the pointed end of a spudger, pry up and disconnect the back panel connector.
Remove the three T3 Torx screws securing the loudspeaker:
One 4.1 mm screw
One 2.7 mm screw
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Use a pair of tweezers to remove the loudspeaker.
If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
2 участников успешно повторили данное руководство.
