Google Pixel 5 Rear Camera Assembly Replacement
Выберете то, что вам нужно
  1. Google Pixel 5 Rear Camera Assembly Replacement, Heat the bottom edge of the screen: шаг 1, изображение 1 из 1
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    It would be helpful to know for how long ally the heated pad
    Yuri Deglin - Ответить
    Agreed, my friend from the past.
    Albert Einstein -
    If you click on the "iOpener" link, it tells you to heat it up for 30 seconds, and if you're using a microwave with a carousel, make sure it moves freely.
    Azurina Schalk-Smith - Ответить
    How long do you think it would take with a hair dryer?
    Gen L. - Ответить
  2. Google Pixel 5 Rear Camera Assembly Replacement, Screen removal information: шаг 2, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Screen removal information: шаг 2, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Screen removal information: шаг 2, изображение 3 из 3
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Please remove the image of the pick in the bottom of the phone in Step 2. This led me to place a pick there BEFORE step 5 which damaged my digitizer. Now I have to replace the entire screen as a result.
    Alternatively, add the image from step 5 with the suction cup in place, or just draw an arrow digitally to the seam you're referring to in step 2. Or call "Step 2" "Important Note" instead of a step.
    David Smith - Ответить
    Wow, I'm glad I read this first. I too assumed this step was about inserting the pick, but wasn't sure because it wasn't clearly written that way.
    Agreed with the "important note" idea, along with combining this with step 5 where the context is actually relevant.
    Marco Carag -
  3. Google Pixel 5 Rear Camera Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. Google Pixel 5 Rear Camera Assembly Replacement: шаг 4, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 4, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 4, изображение 3 из 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. Google Pixel 5 Rear Camera Assembly Replacement, Insert an opening pick: шаг 5, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Insert an opening pick: шаг 5, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Insert an opening pick: шаг 5, изображение 3 из 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
    "Insert the opening pick into the gap." NOT the gap under the glass, the second gap... If not you will probably break your screen, at least I did. Especially important if your pixel 5 shipped with the screen gap :(
    Alex Beaven (Nevbox) - Ответить
  6. Google Pixel 5 Rear Camera Assembly Replacement, Slice the bottom adhesive: шаг 6, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Slice the bottom adhesive: шаг 6, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Slice the bottom adhesive: шаг 6, изображение 3 из 3
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  7. Google Pixel 5 Rear Camera Assembly Replacement, Heat the left edge of the screen: шаг 7, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the screen for one minute.
  8. Google Pixel 5 Rear Camera Assembly Replacement: шаг 8, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 8, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 8, изображение 3 из 3
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
    I suggest placing an orientation sticker on the screen so you don't lose track of where that delicate ribbon cable is. I gently bent one, immediately after doing a successful one, resulting in a costly screen replacement. It's important to know that it's incredibly delicate.
    Edward McClung - Ответить
  9. Google Pixel 5 Rear Camera Assembly Replacement: шаг 9, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 9, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 9, изображение 3 из 3
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  10. Google Pixel 5 Rear Camera Assembly Replacement: шаг 10, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 10, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement: шаг 10, изображение 3 из 3
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  11. Google Pixel 5 Rear Camera Assembly Replacement, Open up the screen: шаг 11, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement, Open up the screen: шаг 11, изображение 2 из 2
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  12. Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the screen: шаг 12, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the screen: шаг 12, изображение 2 из 2
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
    I found it easier to use the spudger here rather than the tweezers (which have sharp ends that could damage something if you happen to slip).
    tristanwaddington - Ответить
    some 5a models will have a screw instead of clip , here's a photo https://imgur.com/a/9dZG5pQ
    Daniel Gonzales - Ответить
  13. Google Pixel 5 Rear Camera Assembly Replacement: шаг 13, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement: шаг 13, изображение 2 из 2
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 5 Rear Camera Assembly Replacement: шаг 14, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement: шаг 14, изображение 2 из 2
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
    The curved ends of the blue iFixit Opening Tool helped me reseat the connector when installing the new screen.
    Jesus no wonder the Chinese factory workers kill themselves, this thing is brutal
    Holy Moly - Ответить
    So hard to get this thing reseated to test the screen, even before putting the adheasive round the phone edge to finish the job. What made it particularly hard was that the flex cable on mine seemed very short compared to video's i've seen online.
    Jake Boddington - Ответить
  15. Google Pixel 5 Rear Camera Assembly Replacement, Remove the screen: шаг 15, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement, Remove the screen: шаг 15, изображение 2 из 2
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Where from we can buy the screen. Thanks
    Ajay Sharma - Ответить
    the screen does not fit
    Joel Kelly - Ответить
    After reconnecting the screen, is it necessary to remove a screen protector (if installed) for the a proper screen calibration?
    Maxx - Ответить
  16. Google Pixel 5 Rear Camera Assembly Replacement, Remove the graphite tape: шаг 16, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the graphite tape: шаг 16, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the graphite tape: шаг 16, изображение 3 из 3
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
    On reassembly, I missed the graphite tape installation. Will this be an issue?
    Gene Harriman - Ответить
  17. Google Pixel 5 Rear Camera Assembly Replacement: шаг 17, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement: шаг 17, изображение 2 из 2
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
    Would have been much more helpful to start off by saying to be careful removing this piece so you can reuse.
    Also would have been helpful to say that the kit comes with a new one, so don't worry about saving it.
    lupa - Ответить
  18. Google Pixel 5 Rear Camera Assembly Replacement, Remove the charging plate cover: шаг 18, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    Купить
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  19. Google Pixel 5 Rear Camera Assembly Replacement: шаг 19, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement: шаг 19, изображение 2 из 2
    • Use tweezers to remove the charging plate cover.
  20. Google Pixel 5 Rear Camera Assembly Replacement: шаг 20, изображение 1 из 1
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  21. Google Pixel 5 Rear Camera Assembly Replacement, Remove the midframe: шаг 21, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the midframe: шаг 21, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the midframe: шаг 21, изображение 3 из 3
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
    Removing the midframe may cause a metal-foam spacer above the light sensor to pop out. After placing in the midframe on re-assembly, you can use the tweezers to squeeze the spacer back in between the midframe and the metal divider near the top of the phone.
    Dumpy Sheep - Ответить
    There is a picture of this spacer at https://www.ifixit.com/Guide/Google+Pixe.... To replace it, first replace the midframe. Then, before screwing the midframe back down, use the tweezers to pinch the space together, compressing the foam in the middle, and slide it into place.
    soren - Ответить
    In step 21 (and step 23) the photo showing the spacer shows the cover over the rear camera and apparently the camera itself removed. But this is not required and nor is it instructed in this guide. Confusing for photo to not match what I'm looking at.
    Gregg Lee - Ответить
  22. Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the battery: шаг 22, изображение 1 из 2 Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the battery: шаг 22, изображение 2 из 2
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  23. Google Pixel 5 Rear Camera Assembly Replacement, Remove the shouldered screw: шаг 23, изображение 1 из 1
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
  24. Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 3 из 3
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
  25. Google Pixel 5 Rear Camera Assembly Replacement, Remove the rear cameras: шаг 25, изображение 1 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the rear cameras: шаг 25, изображение 2 из 3 Google Pixel 5 Rear Camera Assembly Replacement, Remove the rear cameras: шаг 25, изображение 3 из 3
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 участников успешно повторили данное руководство.
Robert Boyd
Участник с: 02/01/21
26 386 Репутация
Автор 94 руководств
2 Комментариев
Hi! Will this procedure mess with the IP68 certification?
Mariano Jurío - Ответить
Hi Mariano! That would depend on well you were able to replace the screen adhesive.
Robert Boyd -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 20
За последние 30 дней: 109
За всё время: 11,585
