Введение
This guide will give step by step instructions to removing the headphone jack from a Google Pixel C tablet.
Выберете то, что вам нужно
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
Orient the device so that the headphone jack is in the bottom right corner.
Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
