Google Pixel C Screen Replacement
Выберете то, что вам нужно
  1. Google Pixel C Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Screen Replacement: шаг 2, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 2, изображение 2 из 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    Be very careful at the bottom of the screen, as you can easily tear some screen internal flex cables. If those cables are torn you have to replace the screen
    Hannes - Ответить
  3. Google Pixel C Screen Replacement: шаг 3, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 3, изображение 2 из 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    Hi friend I have a tab pixel c like that
    But screen touch is broken
    Where can I find it ? I'm from Tanzania
    Help me please
    Gmail ikbfils@gmail.com
    Ikb Fils - Ответить
  4. Google Pixel C Screen Replacement: шаг 4, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 4, изображение 2 из 2
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    This is not very useful if there is no way of getting the parts.
    Lorenzo Braschi - Ответить
    Hi i seem to have a loose item in my pixel c causing the backlight to not light up, when it doesn’t i can bang on the device and it will come on.
    my question is if i am able to remove the screen in one piece what type of adhesive do i need to re-glue it also leaving it able to be re heated to be removed in the future if need be
    wambobby - Ответить
Заключение
9 участников успешно повторили данное руководство.
Deborah Iwakiri
Участник с: 04/25/17
522 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S21-G4, Livingston Spring 2017 Участник Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 членов
Автор 11 руководств
28 Комментариев
Where can a replacement screen be located?
Ronnie Williams - Ответить
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Ответить
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Ответить
All very nice but unfortunately useless without knowing where to get the parts :(
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Luigi Abbinante -
DEUTSCH
Ganz ehrlich, diese Anleitung hat mir persönlich nur teilweise weitergeholfen. Die Schritte sind ausführlich erklärt, jedoch fehlen einige wichtige Details wie z.B. die benötigte Temperaturstärke für den Air Heater um den Industriekleber schmelzen zu lassen, um das Display zu entfernen.
Dafür hätte ich mir gerne mehr Informationen gewünscht anstatt ‘stundenlang’ selbst zu experimentieren. 250°C und mindestens 2 1/2 Minuten einmal ringsherum föhnen hat den gewünschten Erfolg gebracht.
ENGLISH
Honestly, this guide only provided partial help. The steps are explained in detail, but some important details, e.g. the required temperature for the Air Heater to melt the industrial adhesive to remove the display were lacking. For that I would like to have more information instead of 'experimenting for hours' myself. 250 ° C and at least 2 1/2 minutes of guiding the heat around the frame has brought the desired success.
Kundenmatrix69 - Ответить
Hi, did you find a spare display?
Luigi Abbinante -
Did anyone find where to get a replacement screen?
Jon Dixon - Ответить
Did anyone ever find a replacement screen?
Where can we get a new screen?
Kyle Smutny - Ответить
Nobody have lcd assembly for this?????
Reparactif - Ответить
It seems the ifixit staff abandoned this article after creating it, as I see a lot of repeat questions regarding where to acquire a replacement screen but no answer.
I’d like to know where to acquire adhesive to get the screen tightly back in place, after I’ve opened it up. Not to mention the best way to use a heat gun on the screen, to make sure no harm comes to the screen or the parts inside.
This article is nice, but no where near complete.
Mike - Ответить
Where to buy the replacement screen???
danchee - Ответить
i checked that site its a scam one dont buy there ^^^i contacted some reapir shops they told me there are no parts worldwide aviable …. if someone got an broken pixel c i would but the digitizer from it
fiare FoXx (SkyFox) - Ответить
There is a MAJOR flaw with the Pixel C, the LCD ribbon! If you've had you Pixel C for any length of time, you may notice a "half-screen" blackout, or multicolored pixels. I have been through 4 now (under warranty trades) and all four did the same thing after a month or two. What I found was that the ribbon connecting the system to the LCD was loose, but this was not the issue. I found where the manufacturer had glued the LCD terminal ribbon to the LCD was partially ripped (no I did not rip it separating the unit). The ribbon appeared to be brittle and very fragile. I suspect that when the unit gets hot (playing games, etc.) and the constant pressure of taping the screen near this ribbon caused it to rip. This is an engineering flaw and the only solution is to keep replacing this digitizer screen when is starts to misbehave. Spend you $$$ on something more reliable, like a Samsung.
Eric Anderson - Ответить
I have the same problem. A repairer told me the parts is not available in US now. It can be ordered from China. However, he suggested me to just give up and buy another tablet(of course - not Pixel c). It will take more than two weeks to get it shipped.
William Wu - Ответить
Hi Mr. Wu.I noticed what you said ‘lt can be ordered from China’. my pixel c screen was crack. l live in china if that repairer could tell u where is the china screen factory. I can help u buy this parts and sent to your place by ups. i really like pixel c,pls help me,
u can contact by hewenxin1995@gmail.com. thanks.
GUAGUAGUA -
I have a Pixel C and the touch screen stopped working intermittently and now is completely dead. I called Google but it is 6 months out of warranty (2 year). They won’t help any further and told me that a replacement screen can’t be bought. If an address in China is found, please share it as I like the Pixel C very much and don’t have the money to buy a replacement.
Milan van Tuin - Ответить
HI my name Graham
Can please help me on pixel c tablet for some when I power up it's not coming on have try to do a hard reset but still want to come on.
Thanks
Graham
Graham - Ответить
Hi my name is graham can you please on my pixel c tablet whe I power up it's not coming online to a hard resetbut still will come on.
Thanks
Graham -
The backlight of the screen suddenly failed, I want the check if the cables have some loose. I use the hair dryer and blade to pry the screen off , but the touch screen unexpectedly failed. I have done a lot of this stuff to the apple products, even if I crack the screen the functions remain good.
Google pixel C, What a garbage product, from all aspects!
JiangLee Lee - Ответить
Has anyone found a replacement LCD?
j-cast c - Ответить
Me too am looking for the LCD part so any one can help plz contact me at kasim.y.adam@gmail.com
Kasim adam - Ответить
No replacement screen is available anywhere in world. Its not even possible to repair it though google US directly. You can bin the tablet
harcix - Ответить
Hallo anyone,
where can i buy a pixel c touchscreen replacement?
Please share with me the shop.
Its can”t be possibility to leave customer with pixel c alone.
To bad support!!!!!
Duc Dang - Ответить
Investigue y el problema más común en estás tablet es que el regulador de brillo deja de funcionar pero yo no sé cómo encontrarlo si alguien sabe se lo agradecería que me pase la información mi correo de contacto es el siguiente santydtkt12@gmail.com gracias entre todos ojalá encontremos una solución
santytkt665 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 54
За всё время: 17,426
