Введение
This guide walks you through the process of removing a speaker from a Google Pixel Slate. Before attempting to proceed with this guide, a user should understand how to use a screwdriver. In order to replace the speaker and reassemble the device, follow the steps in reverse.
Выберете то, что вам нужно
Orient the Google Pixel Slate so that the screen is facing upwards.
Use the iFixit opening tool to separate screen from main body.
Use the suction cup to remove the screen from the body of the device.
Gently disconnect the three flat-wires from the screen.
Carefully separate and remove the screen from the body of the device.
Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
Remove the thin metal plate from the device.
Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
Detach the speaker wire from the motherboard.
Remove the adhesive strips that hold down the speaker wire.
Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
Pull back the brass plate.
3 участников успешно повторили данное руководство.
