Выберете то, что вам нужно
Flip the device so that the back is facing up.
Peel the rubber stoppers off the top and bottom of the device.
Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
Use an iFixit opening tool to pry up the back panel cover.
Remove the single 2 mm screw using a Torx T3 screwdriver.
Disconnect the orange cable from the base of the device.
