Введение
Drone fan-blades can get damaged and need replacement over time. The damage is caused due to hitting a wall or different objects in the environment while flying. This guide helps you change the fan-blades for the GoolRC X1 RC Drone.
Выберете то, что вам нужно
Unscrew the different sets of fan blades by rotating the T5 screws to the left.
Unscrew and remove the two T5 screws from the bottom of the set by rotating to the left.
To reassemble your device, follow these instructions in reverse order
