Введение
This guide will help you replace the front wheels. A small metal tool is required to remove the wheels. A key or screwdriver will work.
Pull the sleeve covering the base of the wheel back from the wheels to expose the small metal button.
Use a key or other thin object to push down the button holding the wheel in place.
Еще один человек закончил это руководство.
