Введение
This guide shows how to locate the screws on the handle cover and remove them to allow the handle cover to come off. This is only necessary if there is a problem in collapsing the stroller.
Выберете то, что вам нужно
Flip the stroller over so that the screws on the handle are facing upwards.
Locate the four 22 mm Phillips screws on the underside of the handle.
Using a Phillips #1 screwdriver, remove the four 22 mm screws and set them aside.
2 участников успешно повторили данное руководство.
