Введение
Use this guide to replace the speaker on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The speaker replacement includes the speaker and battery replacement.
Выберете то, что вам нужно
Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
There are two screws on the rare case of the device. For the one shown in red marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
Remove the two 9mm Phillips #1 screws from the rare case of the device.
Using opening plastic tool, pry the two grey cases from both sides of the device.
While pry off the grey cases, hold the device with your other hand to remove the cases.
Pry the edges of the device to separate the front case away from the rare case.
While prying the edges, hold the device with one hand to pull out each case a part.
Remove the 7mm Phillips #1 screw from the mother board.
Place the screw in a secure place.
Pick up the motherboard.
Solder off the speaker from the device's case.
Solder off the speaker from the mother board.
Replace the speaker.
