Введение
Use this guide to replace the power jack on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The power jack replacement includes the power jack and battery replacement.
Выберете то, что вам нужно
Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
Remove the two 9mm Phillips #1 screws from the rare case of the device.
Using opening plastic tool, pry the two grey cases from both sides of the device.
While pry off the grey cases, hold the device with your other hand to remove the cases.
Pry the edges of the device to separate the front case away from the rare case.
While prying the edges, hold the device with one hand to pull out each case a part.
Remove the 7mm Phillips #1 screw from the mother board.
Place the screw in a secure place.
Pick up the motherboard carefully to look at the power jack wires.
Solder off power jack from the mother board.
Replace the power jack.
