GravityLight Mounting Post Replacement and Spring Replacement
Выберете то, что вам нужно
  1. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: шаг 1, изображение 1 из 2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: шаг 1, изображение 2 из 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Mounting Post Replacement and Spring Replacement, Opening the Device Housing: шаг 2, изображение 1 из 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Back Panel Screws: шаг 3, изображение 1 из 1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  4. GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: шаг 4, изображение 1 из 3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: шаг 4, изображение 2 из 3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: шаг 4, изображение 3 из 3
    • Firmly grasp both parts of the back panel and pull them apart.
  5. GravityLight Mounting Post Replacement and Spring Replacement, Orienting the Middle Section: шаг 5, изображение 1 из 1
    • Place the middle section on a sturdy surface.
    • Move any wires in front of the mounting post.
  6. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: шаг 6, изображение 1 из 2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: шаг 6, изображение 2 из 2
    • Push down on the spring.
    • The spring is very stiff. Compressing the spring requires a moderate amount of force.
    • Push the spring and the mounting post away from the middle section and remove them from the pocket.
  7. GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: шаг 7, изображение 1 из 2 GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: шаг 7, изображение 2 из 2
    • Pull the mounting post out of the inside of the spring
Заключение
Jamie Forslin
Участник с: 09/26/14
143 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-2, Forte Fall 2014 Участник Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 685
