Введение
These 6 steps explain to remove bottom and top covers.. at the bottom side remove the plate (2 screws) which hold the flywheel axle.. this is your opening to replace the 2 belts, forst the biggest belt for the flywheel, the the midsize belt for the drive.. all good..
I have ordered a new belt set on aliepxress, to be continued once i received them
These are the 3 belts needed (if all) for the TK125, the biggest is needed for the flywheel, the midsize of for the drive and the smallest of for the counter.
Now remove the bottom and the top covers so you can reach both sides of the recorder
Remove the flywheel axle restplate, here is your opening to replace both the belts
first you place the large flywheel belt, then you place the midsize belt for the drive
