Введение
Replacing the bacterial filter in HAMILTON-C1 assures non-contamination in ventilator’s inspiratory and expiratory gas paths. Keep in mind that all bacterial filters are single patient-use only! This is the bacterial filter replacement guide for a COAXIAL circuit setup. To find the bacterial filter replacement guide for a DUAL LIMB circuit setup, click here: HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
For more information on specific types of filters offered by Hamilton Medical:
For more information on using filters for COVID-19 and other extremely infectious diseases:
Orient Hamilton-C1 so the right side of the device is facing you.
Disconnect HME (heat and moisture exchanger) and flex tube
Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
The HME should still be connected to the overall circuit setup.
Disconnect HME and circuit setup
Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
