Выберете то, что вам нужно
Remove back of tablet using the plastic opening tool
Slide the opening tool between the back of the tablet and the digitizer
Lift along the edges until the back of the tablet and the digitizer are separated
Remove yellow tape around the edges of the battery
The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
Lift the bronze, L-shaped ribbon
The camera is attached to the end of this ribbon so it will move with it
Flip up the black bar located on the motherboard
The black bar is to the left of the camera, where the ribbon is attached to the motherboard
