Выберете то, что вам нужно
Remove back of tablet using the plastic opening tool
Slide the opening tool between the back of the tablet and the digitizer
Lift along the edges until the back of the tablet and the digitizer are separated
Remove 4 screws located on the red motherboard
The red motherboard will be loose, but does not need to come completely unattached
Remove 7 screws located around the edges of the tablet
5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
Lift digitizer from the screen
After removing all of the screws, the screen should easily separate from the digitizer
