HKC P774A LCD screen Replacement
Выберете то, что вам нужно
  1. HKC P774A LCD screen Replacement, Digitizer: шаг 1, изображение 1 из 3 HKC P774A LCD screen Replacement, Digitizer: шаг 1, изображение 2 из 3 HKC P774A LCD screen Replacement, Digitizer: шаг 1, изображение 3 из 3
    • Insert the flat end of the spudger into the side of the device
    • This will create a gap between the device and screen housing.
    • Insert the plastic opening tool into this gap and move it along this gap.
    • Make sure not to bent the digitizer during this step.
    • The screen housing and device will now be separated.
  2. HKC P774A LCD screen Replacement: шаг 2, изображение 1 из 3 HKC P774A LCD screen Replacement: шаг 2, изображение 2 из 3 HKC P774A LCD screen Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
    • Two small black pins (circled in red) will need to be unlocked.
    • Unlock the pins by pulling them outward with the tweezers.
    • Make sure the pins are released entirely before attempting to remove the band.
    • Remove the band using the tweezers.
  3. HKC P774A LCD screen Replacement: шаг 3, изображение 1 из 3 HKC P774A LCD screen Replacement: шаг 3, изображение 2 из 3 HKC P774A LCD screen Replacement: шаг 3, изображение 3 из 3
    • Once the digitizer has been disconnected from the motherboard, the LCD screen must be removed from the digitizer.
    • Push open the tabs (circled in red) using the flat end of the plastic spudger.
    • Be sure not to bend the digitizer while prying.
    • Continue to release all tabs while continuing to pry the LCD away from the digitizer.
  4. HKC P774A LCD screen Replacement, LCD screen: шаг 4, изображение 1 из 3 HKC P774A LCD screen Replacement, LCD screen: шаг 4, изображение 2 из 3 HKC P774A LCD screen Replacement, LCD screen: шаг 4, изображение 3 из 3
    • Once the digitizer has been removed, the LCD can be disconnected from the motherboard.
    • Use the tweezers to unlock the black pins (outlined in red) that connect the LCD band to the motherboard.
    • Once the pins have been removed, pull the band out using the tweezers.
    • Make sure not to damage the band when removing the pins.
Заключение
Еще один человек закончил это руководство.
Sean McCauley
Участник с: 10/26/15
512 Репутация
Автор 4 руководств
Команда
Montana Tech, Team 10-1, Shirk Fall 2015 Участник Montana Tech, Team 10-1, Shirk Fall 2015
MTUM-SHIRK-F15S10G1
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 475
