Выберете то, что вам нужно
Insert the plastic opening tool between the digitizer and the case.
Place the spudger in the gap created by the plastic opening tool to assist in separation.
Slide the spudger along the perimeter of the device to fully separate the two pieces.
Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Suck up the leftover solder using the desoldering pump.
Remove the wifi antenna from the motherboard.
