Введение
The battery is attached to the back of the device's display. In this guide, you will desolder the battery connections to the motherboard and remove the battery from the device. This guide requires soldering; please be careful and ventilate the room.
Выберете то, что вам нужно
Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
Pull the bright blue-green tabs to remove the battery from the rest of the device.
If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
2 участников успешно повторили данное руководство.
2 Комментариев
Do you know where to buy a replacement battery for this device?
Hi Nathan,
Unfortunately HP has not released this battery for sale to the public, as seen at https://parts.hp.com/hpparts/Search_Resu.... It may be worthwhile to contact HP. Here is an email address for their customer service: ''HPparts.sales.ams@hp.com.
