Введение
This guide will walk you through the step by step process of removing and reinstalling the disc drive in your HP-BA078DX
Выберете то, что вам нужно
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
Еще один человек закончил это руководство.
