Запчасти
Никакие детали не требуются.
  1. The first step you should take is to turn the laptop off.
    • The first step you should take is to turn the laptop off.
    • Next you want to get the prying tool and wedge it into the seam of the screen and outer casing.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off. Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off.
    • Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • While prying off make sure you have a good grasp on the computer. You will know it is coming off due to the audible clicks
  4. Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit,  this will allow the screen to pop off easily. Once all the screws are removed, gently remove the screen from the outer casing.
    • Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit, this will allow the screen to pop off easily.
    • Once all the screws are removed, gently remove the screen from the outer casing.
Заключение
Nicole Mathieu
Участник с: 19.03.2018
557 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 Member of UMass Dartmouth, Team S2-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S2G4
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 9
За всё время: 129
