Введение
This guide will show you how to safely remove the motherboard from your HP 15-ay014dx laptop.
Выберете то, что вам нужно
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
Pull the back cover off.
Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
Pull out the SATA power ribbon using the tweezers.
Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
Remove the hard drive.
Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
Using the size #00 Phillips screwdriver remove the single screw holding it in place.
Disconnect all ribbon connectors by flipping up the black tabs and gently pulling them out.
Disconnect the speakers by gently pulling the connector out.
Disconnect the Fan by gently pulling the connector out.
Disconnect the power by gently pulling the connectors out.
2 участников успешно повторили данное руководство.
