Введение
This guide will show you how to easily replace your optical drive.
Выберете то, что вам нужно
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
2 участников успешно повторили данное руководство.
