Введение
Use this guide to replace a broken fan that is showing signs of overheating, loud whirring noises, or odd smells.
Выберете то, что вам нужно
Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
Remove the rubber feet on the bottom of the device to access all the screws.
Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
Gently remove the optical drive (CD reader) to more easily separate the base.
Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
