Выберете то, что вам нужно
Slide the two battery lock latches on the back of the device to the “unlock” position.
Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
Locate the optical disc drive and remove it from the device by sliding it straight of the device.
Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
Use a spudger to carefully remove the border around the display screen.
Remove the two 5/16 screws in the top corners and the four in the bottom corners.
Carefully pull the screen from the hinges and lower it on to the table.
There will be wires running from the screen to the motherboard. You do not need to unplug these.
Еще один человек закончил это руководство.
