HP 15-ba0709dx Back Cover Replacement
Выберете то, что вам нужно
  1. HP 15-ba0709dx Back Cover Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Back Cover Replacement: шаг 2, изображение 1 из 1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Back Cover Replacement, Back Cover: шаг 3, изображение 1 из 1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Back Cover Replacement: шаг 4, изображение 1 из 1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Back Cover Replacement: шаг 5, изображение 1 из 1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Back Cover Replacement: шаг 6, изображение 1 из 2 HP 15-ba0709dx Back Cover Replacement: шаг 6, изображение 2 из 2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Back Cover Replacement: шаг 7, изображение 1 из 1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Back Cover Replacement: шаг 8, изображение 1 из 2 HP 15-ba0709dx Back Cover Replacement: шаг 8, изображение 2 из 2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
Заключение
Еще один человек закончил это руководство.
Lydia Brown
Участник с: 03/20/17
369 Репутация
Автор 2 руководств
Команду
Texas Tech, Team S13-G3, Bennett Spring 2017 Участник Texas Tech, Team S13-G3, Bennett Spring 2017
TTU-BENNETT-S17S13G3
5 членов
Автор 5 руководств
2 Комментариев
Make sure to use a very thin shim, but strong enough to pry.
spotty118 - Ответить
thanks- also worked for 15-ba053nr
Renee Brandt - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 29
За всё время: 2,028
