Введение
Follow this guide to replace the hard drive on HP 15-ba0709dx laptop. This repair may be needed if your computer is showing the symptoms such as freezing, slowing down, or corrupting files.
Выберете то, что вам нужно
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Place the laptop on a clean, flat surface with the bottom side facing up.
Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
Removing the friction pads will reveal two more anchoring screws.
Locate the square, blue hard drive
Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
5 человек успешно провели ремонт по этому руководству.
