Введение
If your laptop's speakers no longer work or do not give quality sound, this is the replacement guide for you.
Выберете то, что вам нужно
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Place the laptop on a clean, flat surface with the bottom side facing up.
Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
Removing the friction pads will reveal two more anchoring screws.
Locate the speakers on the right and left on the bottom on the back of the device.
Pull up on the left speaker to pop it off.
Do the same on the right speaker to pop it off.
