Введение
Reasons to replace the RAM on a laptop are the following:
- Overheating
- Performance upgrade
- Lagging software
- Frequent glitches
This guide will provide steps on how to replace the RAM on the HP 15-db0015dx.
Выберете то, что вам нужно
Power off the device before starting.
Remove the rubber strips that hide the screws using the spudger.
Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
Use the spudger tool to pry open the back cover.
Lift the back panel to access the inside.
Slide the CD drive to the left, and remove.
Unscrew the three battery screws with a Phillips #0 screwdriver.
Lift the battery up, disconnecting the connector first.
Push forward and remove the battery.
3 человек успешно провели ремонт по этому руководству.
